How long the engine sits and will be ok depends on a few factors.
-Where is the engine sitting? Will it collect condensation?
-Have you oiled the engine?
-How often will you lube the engine?
-Are all the holes plugged? Nasty insects and crap can get into it. Not to mention a five year old putting a screw into the carb.
-Are you able to put a socket on the front of the engine and turn it over by hand every so often? If so you should do this every so often. Make sure you remove the wrench and socket. another member forget to do this and now has a $8,000 boat anchor.
If you can answer the above questions with the best possible reply then the engine can sit for years and will be ok.
