Thread: Puking overflow
Old 04-18-2010, 09:21 PM
wetdog wetdog is offline
Cobra Make, Engine: classic roadster,408cu
Default Puking overflow
Getting the bugs out of my build everything ok except for one nagging problem , when I stop overflow pukes coolant ..engine runs at 185 195 deg. cap was changed to a 16# one ,put car on angle and removed temp sensor from intake to bleed air . Every time i pull in from a run it dumps coolant , the overflow is a zirgo unit that holds just less than a qt. could this be too small? has anyone had this problem ? I am all ears to a solution..WD
