Old 04-19-2010, 08:17 AM
sfeakes sfeakes is offline
Thanks for all the help and ideas.
I ended up finding pre-made lines at the local NAPA, I used 60" line with 3/8"-24 inverted flare ends. It was dead simple to bend and make fit. I have those Earls lines james but 10" length that I was going to use to replace the stock rubber line. But I couldn't find the correct fittings / adapters so I'm using stock until I can find them.
I ended up going back to a push slave from GCPC, but had to modify it a bit to make it work in my setup. This will be the earls braided line once I get the fittings.
Added a second heatshield just for the clutch.
Also ended up machining up an extension for the clutch pedal arm, just so I could get more adjustment in pedal location and throw.
