Old 04-19-2010, 07:13 PM
mickmate's Avatar
mickmate mickmate is offline
If you change the pinion flange you need to get the specs and see if it's a crush collar or shimmed pinion. They are typically done up till the torque required to turn them over is to the spec of ? inch/lbs. If you need an inch/lb torque wrench let me know.
mickmate
http://www.actoncustom.com/
