Old 01-01-2002, 10:22 AM
HALLEN HALLEN is offline
Cool Ffr 1910 For Sale!!!
FOR SALE:
FFR 1910
USED PARTS
Stock 302 engine with mass air, runs strong, uses no oil
Resurfaced flywheel
Balance of donor parts
NEW PARTS
T-5 transmission
Motorsport clutch
Battery
Flaming River battery cutoff switch
Centerline Thruster wheels, 15"dia, 10"W rear, 7"W front
BFG radials
front rotors
brake pads and shoes
rear shocks
radiator
Granetelli 190 lph fuel pump
Kirban adjustable fuel pressure regulator
Motorsport dist cap, rotor, plug wires
Summit radiator overflow jug
Finishline roll bar trim rings
Front and Rear main seals, intake and valve cover gaskets.
Ford A/C elim brackets
FEATURES
Power Steering
Dropped Footbox
Upper radiator hose filler "T"
Thermostat-controlled radiator fan
Fire extinguisher
Hood support kit
Trunk lid support
Solid motor mounts installed plus stock rubber mounts in box
Some extra parts-injectors, plumbing, sway bar, etc.
Car is still in gray gelcoat and ready for body prep and paint. Car has about 1500 miles on it and has had the body cured in the sun for two summers. This car was professionally built by an aircraft mechanic and is titled as a 1965 model. This has has been street driven only-no racing. Price for this car is $19,900 and might be negotiable. Feel free to email me if you are interested, I will also try to post a pic but will email pictures to anyone interested.
Bill Allen
FFR1910
