You can get them at summit racing. There are three that most people use. All will fit the diameter of the S&H air cleaner, but they are different heights. I actually bought all three and then returned two of them. In order of preference (these are the summit part numbers):
KNN-E-1015 (tallest, flows best, but didn't give me enough clearance with my hood scoop)
KNN-E-2570 (second tallest, just slightly taller than the stock foam filter and fit my car. This will probably fit most cars. I actually put the screen back around this filter so it looks somewhat original)
KNN-E-9181 (shortest, this is probably almost the same height as the stock foam filter, but would flow the least well)
Doug
www.partskeeper.com
