Old 04-22-2010, 02:08 PM
DAVID GAGNARD's Avatar
Holley's are very easy to work on (IMHO) take it apart carefully, lay everything on a clean towel or whatever and blow out every little hole you can find, you can also run a real fine wire thru them just to be sure, then re-assemble........I've had great luck with the blue non-stick gaskets, avaliable at Auto Zone or most any other parts place.......
David
DAVID GAGNARD
