Old 04-24-2010, 09:13 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by dennis_schaap View Post
Hi,
thanks for the quick reply.
Yes i've checked the sparkplug with one of the wires unplugged and let it spark to ground. I've also checked the distributor cap for any corrosion but thats all looking fine.
I've refilled the fueltank with fresh gasoline but without any result.
conclusion: the ignition sparks but i think the spark is not strong enough to ignite.
I've heard that this type ignition is not very reliable. Does anyone has an idea which type of ignition is reliable?
Thanks!
Dennis.
what are you using for a module? msd? ford? is the module grounded, corrosion of the ground may be hindering efficiency
