Old 04-24-2010, 02:50 PM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
Default Oil leaks again like ____
h3LL....
I took my car out for a drive today and oil everywhere. I didn't see any dripping on the seal but there was some on the gasket for the oil pan in front. I dropped the pan and there was oil between the gasket and the block. Also there is about an 1/8" ledge off of the block to the timing cover. Should that get filled with RTV? Should I be using any sealant between my gasket and block or gasket and pan. I am using a Milodon pan and milodon gasket. the gasket with the steel spacers in it. I would assume that the oil getting in between the block and gasket is a BAD thing.. lol
Should I buy a different pan and gasket.?
