Old 04-24-2010, 09:29 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
by 1/8 ledge b etween the block and front cover do you mean where the gasket surface is???If so you not only have a oil pan leak but probably also a front crank seal leak--
those surfaces have to line up and if they don't you probably have a mis matched or defective front cover
