Old 04-28-2010, 11:05 AM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Byron- yep, all three.
I have been talking with the owner of this company below, and his pulleys. He's very knowledgable and the pulley's look awesome. I only need one grove pulley's. I'll have to see if they have for each pulley size.
Rick- Although the Kirkhams would be top quality, I assume the're very expensive. How much ?
Where do you find parts on thier site ?
http://www.cvfracing.com/390-427-428-pulley-kit
Billet Aluminum Ford FE Engine Pulley Kit
V Belt Ford FE Pulley kit 390, 427 & 428 FE engines. Pulley provides 87% underdrive ratio when used with CVF Racing crankshaft pulley. Designed for use with stock power steering and alternator brackets.
Application
1) Ford FE series engines
Fits vehicles with:
1) Engines without casted V-Groove in dampener
2) 3 Bolt pattern on crankshaft pulley
3) Dampener face to water pump flange face 2 3/8”
Ford Pulley Kit Contents:
Water Pump Pulley
P/N BBFE2WP
Grooves: 2
Pulley Diameter: 6.2"
Pilot Diameter: 0.625"
Crankshaft Pulley:
P/N BBFE2CR
Grooves: 2
Crank Pulley Diameter: 5.4"
Crank Pulley Bolt Pattern: 3 Bolt
Alternator Pulley:
P/N ALTFAN
Diameter: 2.7"
Alternator Shaft Diameter: 11/16"
Alternator Fan Sold Seperately
Available Finishes:
- Machined
Material:
6061-T6 Billet Aluminum
Regards,
Kevin
