This is why it is a good ideal to prime the engine with a drill before starting. Turning the engine over with the plugs out wipes what
oil is on your bearings of and leaves them dry. Prime the engine to make sure that your lines are hooked up correct and to make sure that you are getting
oil pressure before you start the engine. Double check your lines and the way they are routed.
Good luck, Keith
