Old 04-29-2010, 08:51 AM
Mark Thompson Mark Thompson is offline
Cobra Make, Engine: Kirkham #625 427S/C, 468 ci Al block, 615 HP
Thanks for the comments. I should have added to the background that I left the oil from the test work in the engine when I installed it, so the only priming was filling the external lines, filter, and cooler. The "out" line from the adapter plate is common with the sender and goes to the side of the filter mount, which feeds the in holes to the filter as you all have described.
I am increasingly suspecting the pressure sensor/gauge.
Mark
