There was only 1 set in 98
byron w Byron there was only 1 set. Under drive on all 3 pulleys. Crankshaft,Water pump, and Alt. I never installed the ALT pulley. They are like 5" for both water pump and crankshaft. There is a note about overheating if the car sits for a long time at idle. There is not enough flow of coolant through the motor. SBF guys had the same problems. I also did alot of messing to get the temps where I wanted them. Aluminum radiator, grinding out ports in the intake manifold. More steel pipes to stop and rubber hoses from colapsing. larger thermostat center opening. Aluminum motor runs hotter than iron one over all. Rick L.
