Old 04-29-2010, 02:37 PM
madmaxx madmaxx is offline
I thought that was the sportsman block, from what I understand the only difference is one is set up for a dry sump system which they are not using. I suspect components were "donated" for free from manufacturers. When I added up the parts I assumed the sporstman block from Dart.
I wonder why in stage 2 he refers to afr heads but goes with trick flow in stage three, it appears there will be a stage 6 with a dyno, should be interesting.
