Old 05-03-2010, 12:56 AM
westcott cobra's Avatar
westcott cobra westcott cobra is offline
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
@Fraz,
the rover switch positions turned clockwise are:
OFF Connects: 3+5, 1+6
Interm. 4+5+6
Slow 3+4+1
Fast 3+2
That means:
OFF: connected from 3 to 5, motor connection for park position, switched off by the breaker switch in park position
Interm: don't now what kind of relais do you want to use
Slow: connected from 3 to 4, motor connection for low speed
Fast: connected from 3 to 2, motor connection for high speed
Pushing the fluted knob activates the screwed in washer switch, so you can switch ground or power independend from the normal wiper switch connections to drive the washer pump.
@All,
the 2 numbers i posted for " alternative" switches are wrong. I checked all my switches at home and found out that i collected the switches just to get washer switch spares. The 35796 and 39195 are 2-speed switches but will not work with our common wiper motor. Used with the cobra wiper motor they are just 1-speeds because:
35796 internal connections turned clockwise are:
0. 1+2+3
1. 1+2+4
2. no connection
So the switch could be used counterclockwise to drive a conventionel setup not "british" wired
39195 internal connections turned clockwise are:
0. 2+3
1. 2+4
2. 1+4
Sorry for the mistakes,
Uwe
Everything should be as simple as possible - but not simpler !!
