Originally Posted by Keithc8
This truck is a perfect candidate for a 408 Windsor. The kits are real reasonable for them with the cast crank, I-beam rod and cast pistons. I think we can get you a complete kit with bearings and all for about 1000.00 or less.
This would be a much torquer engine for the heavy truck you have. Do the 408 while you have it apart and it will work much better.
Good luck, Keith Craft
Keith:
That sounds good and the 408 surely would provide the torque needed, we would need to find a better set of heads for the 408, the 289 heads would not be enough to make the 408 do it's job, if the deal on the used alum. Edlebrocks comes thru, the 408 would sound real good, I'll let you know.......
Thanks;
David
