Old 05-05-2010, 04:21 AM
Default More important to have the ports flow matched
FUNFER2 Kevin it's more important to have ports flow matched. SGT Joe Craine does and excellent job if evening out all the ports on the manifold. There can be a 10-30 cfm different between ports. When SGT. is done it's like around 5 cfm. All cylinders are getting the same A/F. His work looks like it should be on a coffee table instead of under a hood. If you limit the rpms to 6,200, the dual plane with porting will be fine. Looking for a little extra HP in the top end Single plane. Again let Joe port clean the manifold. I run a single plane for my motor but it is a dry manifold. (FI system)
