OK, no blue dot is good. Check your plugs to see what your F/A mixture is running and check/set fuel bowl levels. If all ok, ck acc pump operation, should shoot fuel as soon as linkage starts, no hesitation. You should have an instruction sheet that came with the carb which covers these points and more on how to dial the carb in to your engine. If not, go to holleys website for detailed info.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
