  #47 (permalink)
Old 05-09-2010, 09:41 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
The EROD Episode is also on itunes -- interesting stuff !
Some recent Notes ;
The fuel system for this thing is a snap.
The EROD LS3 just requires a 59-60psi fuel feed pressure at 45+ gallons per hour.
If you use a GF822 delco filter , ( Wix 33737 )which has an internal pressure regulator you have some major items taken care of. Yes this is a fuel filter with a $40-70 price tag, but - the problems it solves are worth every penny.
You could locate the filter closer to the tank and pump, eliminating the the chore of plotting and installing a significant portion of return line ( save money, labor and frustration) .
The fuel flow requirement is minimum 50GPH, most basic EFI pumps are 97-140GPH so this is not really a hassle.
Fuel line needs to be 5/16-3/8" (AN6)
--more news as it happens !
