Old 05-11-2010, 02:38 PM
psychoSEAL psychoSEAL is offline
Cobra Make, Engine: 351 Windsor
Drained the tank and replaced the fuel filter. Flushed the tank out with gas. The filter that I replaced was one that I couldn't see into. Brass in color similar size to a shot gun shell. Replaced with a Purolator filter. One that you can actually see what is being caught. When draining the tank, I did see in the bottom of the pan that there was what appeared to be rust. But after further inspection it was more on the order of dirt. It would disintergrate by touch. I am going to fill up with 93 octane and see what happens. When I put her in drive hopefully she will run. If not I'll take the carb off and inspect.
