Old 05-12-2010, 03:47 PM
puppster's Avatar
puppster puppster is offline
Default FFR Mark I Steering
My fathers FFR Mark I is set up with 17" wheels and tires, the rest of the combo is pretty much what you would expect on a Mark I. The problem is the steering, it is very scary turning in to corners. You had better be ready when you turn the wheel. There is nothing between going straight and making a right angle turn it seems. The car does not have any sway bars, although we want to add a front bar to help with this issue. I have wondered if it could be a problem with the (probably fox mustang) rack and pinion, but I have not read of any others experiencing the same problem.
The car has been to an allignment shop, and set to fox Mustang specs.
Any help would be greatly appreciated.
Jeff
