Is this something new? or has it always been that way?
Sway bars won't help you.
The FFR front end is pretty simple. Nothing fancy or complicated about it. That's good, because it makes it easy to fix.
The first thing to check is everything. Pull the wheels off, check all the bolts, bearings, steering rack, etc. Make sure nothing is loose or worn out.
The second thing is alignment. This is a big issue, especially with the MI. If your alignment specs are not dead on, it's a handfull.
Finally, check bump steer.
