Old 05-12-2010, 07:14 PM
puppster's Avatar
puppster puppster is offline
The car has exhibited the behavoir since we aquired it.
When the car went in for an allingment, it was noted that a rod end was worn out, so it was replaced. I assume everythig else was checked, but it will be checked again. We do not have any documentation that calls out the allingment specs from FFR. The build manual is very light. I believe the tech. looked up a Fox body Mustang and used those specs. I don't recall what they were. Please pass along the specs if you have them.
If this is a bump steer issue would it happen on smoothe roads? On a nice flat surface it still has this issue.
