Gentlemen, as I have been talking about on the Bay Area Forums, the EROD style of engine is the future of hot-rodding.
I have done 2 shows with GMPP on the EROD concept , and I own a FORD place. we do work on GM as well. -- but its 90% ford based.
The EROD is a clean 430HP+ V8 that depending on gearing can put out 22-25MPG easily and still have the firepower. -- a pushrod engine that meets emissions.
I know its not a 428 , it didnt win lemans ... but there are some very good reasons to consider, and there are some neat features.
The EROD is LS3 based from the 2008 corvette / 2010 Camaro ,
5 speed, 6 speed and automatic choices are many.
Fuel supply just needs to be 60PSI at 90GPH.
the hookup is so easy that you dont need to be an electrical guy.
the fuel hookup is so easy you dont have to be a plumber
they are about the form factor of a 351W ford if not narrower.
The exhaust ports are spaced like a windsor ford.
-- there are many reasons to look at them.
also you may not know, but fully dressed they are 380Lbs!!!!( AL block, AL HEADS !!!)
and the MT EROD is street priced at about 8K with a 2/24K Mile warranty.
Not a bad deal.
Steve
