Originally Posted by Clois Harlan
Ditto, on the running it awhile to get the moisture out of the side pipes. Took mine a couple of days of driving to clear all the moisture. It sounds as though you have done all the right things.
Clois
This is an excellent point. You may have already fixed the problem.
Check the plugs on that side. if they all look the same and one is not clean from steam blasting, then the problem is probably fixed.
