If it is a bump steer issue a sway bar would (I think) help by keeping the suspension from compressing so much.
Are the ride height specs measured from top of tire to wheel opening? I think this will be a good place to start, as the car looks high in the front, however the rear is not set up with coil overs, and not adjustable. Once getting the ride set, we will get it realigned, possibly then go ahead and add a sway bar.
Thanks for all of the tips.
