05-13-2010, 09:29 PM
MD
Originally Posted by 289ACE
If you are grounded through the tail light body check that path. If you have a corroded ground point it could do this. A quick way to check is to get a jumper wire and attach it between a known good ground and the tail light body and see if the light increases in brightness.
Jay
Yes that's the way it's set up. Thanks for the tip. I will look at that tomorrow.
www.partskeeper.com
