Late response...sorry...
Just swa your question....I, too, have an SPF w/ 393 stroker. You didn't mention what distributor you're running, but it indeed has a bearing on your air filter selection. I'm running an MSD6AL, with billet MSD distributor. The distributor cap is wider than the Ford Duraspark cap, and interferes with the K&N 14" drop base filter canister. If you're running the Duraspark ignition, you should be able to use the K&N 14" drop base unit along with their filter, no problems.
I'm running a 13" Ford Motorsports filter canister along with a K&N filter. Fits fine, good air flow. But, there's a clearance problem with most SPF cars so you may be limited on the filter height. I understand the K&N X-Stream filter system actually flows less air than the 13" Ford Motorsports filter set at the proper height. From what I undestand the pleated top actually causes some air turbulence and effectively reduces the air flow. The 'proper' height for the Ford M/S air cleaner is about 3" above the carb intake plenum, higher if you can get it. What you're tying to do is allow the air flow to straighten out after it makes the 90 degree bend and to do that, you need to increase the length of the intake plenum - by raising the top of the air cleaner.
We got all this info fro a dyno tuner in the Charlotte, NC, area. He's known as one of the best Ford tuners in that part of the country. He got about 13 more horses by recommending the K&N drop base unit, but like I said I had clearance problems with the MSD distributor.
I've got all the part numbers at the house if you'd like them. Everything's available from Summit Recing, if you're interested. Let me know...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
