Thanks for the kind words.
As for Clarkson, Jeremy is a little short sighted, what really matters is that the Cayenne Turbo S will run zero to 60 mph in 4.8 seconds. Not bad for 5200 to 5900 lbs depending on options. What's most striking about the Turbo S is the ever present torque. Maximum torque of 530 lb-ft is available from just 2,750 rpm. There's an effortlessness to the way the Turbo S finds any speed the driver chooses.
So what if Jeremy doesn't like the a** end, it's the most comfortable and capable truck you can find if you need to tow something.
Russ
