OK,
You've had lots of answers,
There IS AIR in the system-period. Lot of explanations for what is going on but the problem IS AIR. Jack the nose up as high as you can get it, IF you have a heater make sure it is wide open, loosen up the radiator cap-THEN- start it and run for a few minutes. If you watch the flow in the radiator you will see the large air pockets being pushed out!
No secret here........
