Thread: Dead Cylinder
  #25 (permalink)
Old 05-19-2010, 06:50 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
It sure sounds like no fuel. I never messed with webers but what if you lightly spray the carb.cleaner in the carb. air horn of the bad cyl. while the engine is running. You should be able to tell if the cyl. starts to fire.
Also, is there any vacuum plug or fitting to that intake port that may be causing a lean miss?
