Don't drive and replace both arms
seeda This is the 3 or 4th car I have seen or heard about having lower control arms breaking. The welding was not right. 2 I have seen, the welds where not deep enought between the tube and mounting support. 1 the lower tube crack along the bottom, and the other snapped off a mounting point at the hub.
CWI has billet rear control arms if you want some flash. They also just came out with a tube arm that has toe adjustments and weights about 1/2 of what the old arm weights.
Replaced both arms and have happy drives. Rick L.
