Originally Posted by Nedsel
It wasn't an option. All original Cobras came standard with the Dana-Spicer "Powr-Lok" limited-slip differential.
That would make sense. I guess the article got it wrong back then. Here is the specs that they printed:
Street: $7495 FOB LA
* Iron engine with two Ford, four-barrel carbs.
* HP - 425 @ 6000 rpm
* Torque - 480 @3700 rpm
* Curb weight: 2450 lbs.
* Fuel Tank: 18 gal.
* Wheel Size: 7.5 x 15 in. (front & rear)
* Gearbox ratios:
1st - 2.23 to 1
2nd - 1.69 to 1
3rd - 1.29 to 1
4th - 10 to 1
* Limited Slip Diff. -
optional
* Suspension: Large coil springs, tubular shock absorbers, front sway bar.
* Brake Discs:
10.5-in, front
10.5-in, rear
* Standing quarter mile with equipment as tested: 13.2 sec. @ 110 mph
www.partskeeper.com
