  #22 (permalink)
Old 05-20-2010, 04:03 PM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Sid,
I am trouble free for over a year, I think I have it licked. I bought a larger master and Bill Littleton's slave set up to make and made sure the bores match. With the lines wrapped, rerouted and fluid changes - it worked fine. The trick was the adjustable rod in the slave and moving the clutch peddle all the way forward. I had the guys over at Komet fix it get it adjusted perfectly. You guys are welcome to take a look at it if you think it will help you. When are you going to Chris' house? Oh, I think I can make it for lunch for a while in between games.
1/4 mile 11.92@115.6 and 60ft 1.632
