  #28 (permalink)
Old 05-21-2010, 06:06 AM
kayakjack's Avatar
kayakjack kayakjack is offline
Originally Posted by PANAVIA View Post
That sounds like too much oil to me for that setup, and the oil sounds a bit too thick , that oil temp also sounds high, and are you saying you are cruising at 5000?
Should be about 9.5 to 10 qts depending on pan.
Steve
Interesting. I also have the 351 Windsor Ford Racing 385 hp engine. Bulletproof. I change the oil once a year. I use Mobil1 0-40. Burns no oil - no need to add anything between changes. Around 60 lbs pressure.
But 7 quarts fills it. Do these engines come with different pans?
Jack
