Along time ago, I went to a brake locking system. There are many available like B&M Roll Control or one by Hurst. The best and yes the most expensive at $340 each is by Mico Hydraulic. There web site is tsmmfg.com/mico_hydraulic_brake_lock.htm. These are designed for brake lines of heavy equipment in the construction industry where cable type emergency brakes could fail becuase of corrosion on the cables. They are not made for use for a long time as your pads could rust in the closed position. The are ideal for disabling your vehicle thought. Push down on the brake pedal and press the button and the solenoid closes mantaining the pressure in the line. I set them up for the rear brakes. Also, consider marking the button on the dash-HORN, howmany car theives would want to press the horn button?
Billk
