Goodluck to you aswell Craig. Have you got a licensed SLC on the road?
I am not looking for an Ultima Vs SLC thread but thanks for your input. I have no interest in RCR or the SLC. Others may and I recommend that they contact you or start a new thread.
Ok back to Ultima's
Thanks to all the people that emailed, pm'd and called regarding Ultima's.
I am not the dealer or Australian Rep, I am very happy to help with what I can and discuss ADR's and so on.
I have put Alan's contact details below.
Contact him for prices and so on or just go to the Ultima webpage and get all your own info.
Alan May
Mayhap Holdings
Ultima Australia
15 Woodalla Way
Narrawallee NSW 2539
Ph. 02 44555520
Mob. 0417 270 135
alan at mayhap.com.au
Here's what I am thinking of getting
STAGE 1
MIG welded round and square tube spaceframe chassis,
Fully bracketed to accept Chevrolet V8 engine and Porsche
transaxle, steering, fuel tanks, seat belts, pedals, radiator,
handbrake, gear linkage and brake servo mountings.
All powder coated in black satin finish. $4832
STAGE 2
Alloy panel kit in NS4 16swg aluminium sheet polythene
coated both sides for cockpit floor, sides and bulkheads,
pre-cut and bent including bonding adhesive, pop rivets
and skin pins. $404
STAGE 4
TIG welded wishbone set with urethane bushes and plated
fixing nuts bolts and washers. $897
Front suspension upper and lower ball joints. $138
STAGE 5
Rear uprights in LM25 heat treated alloy, fully machined
to accept Ford manufactured hubs, bearings and brakes.
Including all plated fixing bolts, nuts and washers. $795
Rear toe in adjusters including rose joints and fixing bolts.
$211
Front uprights in LM25 heat treated alloy, fully machined
Including steel steering arms. $795
STAGE 6
Front set of wheel hubs, wheel bearings,
oil seals,
dust caps, hub nuts, washers and long wheel studs.
$452
Rear set ditto. $972
STAGE 8
Steering column complete with universal joints, bearings
and fixing bolts. $356
Sports alloy steering rack with 2.5 turns lock to lock complete
with track rods, track rod ends, alloy mounting clamps,
fixing bolts and rack boot kit.
$356.4
STAGE 9
Front mounted radiator and cooling kit comprising of five row
radiator, preformed alloy water pipes, twin fans with water
temperature sensor thermostat, alloy expansion tank,
alloy swirl pot and all fixing brackets.
$1212
STAGE 10
G50 gear linkage in 20mm CDS including all needle roller universal
joints and chassis fixing rose joints. All plated.
Gear lever 1/2" rod.
$602
STAGE 11
Foam filled alloy petrol tank with - 6 fittings, fixing kit, tube
type fuel gauge sender unit, aircraft type external flush filler
cap, alloy mounting, filler hose and clips. 40 litre capacity.
$762
STAGE 15
GTR bodywork in GRP with Isophthalic high heat
distortion resin comprising front and rear sections, side pods,
cockpit, doors, dashboard, headlight and instrument pods.
All in coloured gelcoat.
$6872
STAGE 16
Front and rear body hinges, door locks, door hinges, gas struts,
body securing latches and releases.
$848
STAGE 17
GTR laminated glass windscreen, polycarbonate sidescreens,
GTR perspex headlight covers.
$933
Options
Full roll cage in 38mmx3.2mm wall thickness CDS as single
hoop but with hoop around windscreen braced back to rear hoop.
$1518
Remove and buff up all flash lines, cut out all apertures for lights,
trim all returns to correct size. $1234
Total $23833 Wow
Freight /gst/ duty approx $9271
So for approx 33k you have most of the parts to build a roller. I will source my own shocks, wheels , interior trim and so on. I'm guessing on the road for 80k using a stock LS1. You don't have to paint these cars because the gelcoat is so good so that saves 10-15k. Just like B ig Kev use to say "I'm Excited"
