  #59 (permalink)
Old 05-22-2010, 03:56 PM
patrickt patrickt is online now
Originally Posted by dcdoug View Post
Your right.
Yes, that phrase should become a "sticky." I'm betting your speedometer is just off. I use my tachometer as my speedometer -- the tach is very accurate. Use a GPS to check your speed. You can check your rear by rotating the tires while it's jacked up. I guess you could check your 5th gear by peeking in to the fork hole while you did that too.
