Old 05-22-2010, 05:35 PM
tcrist tcrist is offline
Mike,
An 8.8 is a lot different than a 9". At least you have the 4 post and as long as you have the jacking brace that goes to the 4 post you should not have too much of a problem working on it.
When you take it apart be sure to keep the shims from each side separated so you can measure them. At least it will give you a starting point.
I have a mag base dial indicator if you want to borrow it.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
