Old 05-23-2010, 12:42 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Mike,
Yes they will but as with almost everything not supplied by CR's the back of the dash will need some attention where the switches go. I use Lucas a lot but their threaded shafts as you know are much to short to work well.
I use a 2" MINI GRINDER and just grind down the dash where the switch will be. Then you can put the Lucas switch in with room to spare. I've even done it numerous times with the pad on the front- just grind slow and cautious!
