Old 05-24-2010, 04:52 AM
blykins blykins is offline
Default Complete Cobra Drivetrain Packages
Get everything you need from one supplier:
Small Block Packages
*RAM Pilot Bearing/Bushing
*RAM Billet Steel Flywheel, 157T, 10.5" Diaphragm Clutch Pattern
*Quicktime Bellhousing
*RAM Powergrip Clutch Kit, 550hp Capability
*Clutch Fork
*Tremec TKO 600 Transmission
*Steeda Tri-Ax TKO 600 Shifter
*ARP Flywheel/Pressure Plate Bolts
$3360
FE Packages
*RAM Billet Steel Flywheel, 184T, 11" Long Clutch Pattern
*McLeod Clutch Fork
$3485
We can supply any parts that you need to complete the installation of your Cobra powertrain/drivetrain package. If you need a custom clutch kit for your particular application, we are distributors for McLeod, RAM, and Hays. Whether you need a King Cobra clutch kit or a drag race Soft-Lok, we can get whatever you need.
B2 Motorsports can also supply any of your engine needs, whether it be a short block, a complete engine, or a complete drivetrain package from water pump to rearend.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
