Old 05-25-2010, 09:09 PM
LeonardU LeonardU is offline
Cobra Make, Engine: Contemporary, 427 SO
Default Bleeding the Slave Cylinder
I have tried gravity bleed, pedal bleeding and vacuum bleeding with unsatisfactory results. My pedals are not floor mounted and the reservoirs are not high enough above the master cylinders. I don't know what you mean by bleeding from the bleeder on the slave. I am not familiar with the Phoenix system; would you describe it for me. To say that pressurizing from the reservoir down does not work at all on a slave cylinder may be an overstatement on your part. It is the only method that has worked for me. I am not an expert, but a novice who is trying to learn.
Len
