  #23 (permalink)
Old 05-26-2010, 03:48 AM
Maurice Butler's Avatar
Maurice Butler Maurice Butler is offline
Cobra Make, Engine: Scratch build, with help
The misconception with ride height is people think it's what looks good. Ride height should be engineered for a specific roll centre and centre of gravity on the car
This is why didn't specify a figure. The started with orginal had 5" between the chassis and the ground at the front and 51/2" at the rear. As these were modified over the years by owners. These figures changed dependant on tyres, rims, modified suspesion arms, etc.
As every kit has there own thoughts on what makes a good handling car the suspension mounting points, suspension arms, uprights all could have slight varations due to enginneered improvements. Therefore you need to start with your with the manufacture recommendations.
You could also spend time with a string computer and reverse engineer the ride hieght, only still be out.
In NZ the law states for road registration the ground clearance between the chassis and the ground must be 4". All the young lads & girls with there lowered jappers keep running fowl of this.
Maurice
researching for scratch build
