One more comment on the sway bars . After setting the wheel weights , cross weights , alignment etc , make sure the sway bars do not have to be pulled into position as that will undo everything you just did . On mine , we had to fabricate a new connecting rod as when we got the first side connected , the second was off about 3/8" . Now the bars are installed with zero preload ..... front and rear .
