Old 05-26-2010, 10:49 AM
jhv48 jhv48 is offline
Default Mechanical Fuel Pump Install.
Getting the mechanical fuel pump off of my Roush motor is easy. Two bolts, pops right off. However, when trying to reinstall it, I was unable to compress the lever on the fuel pump that follows the eccentric on the camshaft so that I could line it up and install the two hold down bolts. I must have just removed it when the lever was fully compressed on the high point of the lobe.
Did I just happen to remove it whent he rod was fully compressed thus making it hard to reinstall?
Should I turn the motor over till the low point of the cam is even with the lever? What is the trick. I never had this problem with a fuel pump before.
Jim
