Old 05-31-2010, 08:40 AM
Roush #1's Avatar
Roush #1 Roush #1 is offline
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Kevin,
Yes, I use that thermostat housing.
It took about 2 hours in all to stop the leaks.
My housing leaked until I machined enough of the housing away to get at least thirty thousandths of an inch of compression on the O rings.
If you go ahead and machine the housing before you start you wil save a lot of time.
I installed, removed and modified the housing 3 times before I stopped the leaks.
I think you would be wise to replace the O ring if you remove the housing.
They are cheap and readily available.
Hope this helps.
Good lluck!
J
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
