Old 06-01-2010, 09:58 AM
bobinyelm bobinyelm is offline
Cobra Make, Engine: Backdraft, 351W
Default Clutch Hydraulic Problems
I just got my car on the road (well, sort of-I am awaiting a new non-binding steering rack from Reg before I can have it inspected), and after only two 10 minute test drives in the neighborhood, the clutch went out.
No external leaks, and it was bled perfectly. I suspect the master is bypassing the fluid, though I need to investigate further.
I am reading a LOT of old posts about hydraulic problems, mostly due to heat.
My 351W engine only has maybe one hour run-time on it (half idling w/ the hood open). Is this enough to cook the master cylinder?
I have the factory heat shield and the push-type slave cylinder on mine.
If it's heat-related, has anyone explored a small blower mounted somewhere and ducting cool air at the brake and clutch master cylinders?
I tried reaching in there, and even though the hood was open the entire time I had the engine running (maybe 5-8 minutes) the air and cylinder temperatures were more than what a human hand could stand.
Most of the clutch posts are over 2 years old. Does this mean there has been a "fix" I am unaware of? My MSO has "C/N 661" in red at the bottom, so I guess this is my chassis number?
Any insight much appreciated!
BTW, I read the master is from a 1985 Mazda truck-is this true if I need another one?
Bob
