Old 06-01-2010, 11:04 AM
bobinyelm bobinyelm is offline
Cobra Make, Engine: Backdraft, 351W
Default What Oil Filter for a 351W?
Just got my car together, and installed the engine with a "standard" Wix oil filter already on it.
I didn't notice until after the engine was in that there is only 1/2" clearance between the end of the filter case and the chassis.
I doubt I will be even able to remove the filter when the time comes, much less get a new one on there.
Obviously, I can Sawzall the end off the present one and remove it in two (very messy) pieces, but is there a shorter filter that will work w/ the engine with the proper relief valve or anti-flow-back valve as the OEM filter possibly has?
I was planning to install an oil cooler via an adapter under the filter, but cannot imagine even w/ a shorter filter there would be room.
Is everyone running a remote oil filter, or just a shorter one?
Thanks,
Bob
