Old 06-01-2010, 01:55 PM
snakebittexan's Avatar
snakebittexan snakebittexan is offline
Cobra Make, Engine: BackDraft, Keith Craft 408; 1967 GT500CR
Hi, I just changed my wheel out on my BDR. Use fishing line to pull the center cover off your wheel, remove the center nut on the boss then use a steering wheel puller to pull the boss off. Once off have it drilled to match your new wheel's pattern and replace. Keep the puller until you have the wheel properly centered, it'll take a couple of trys to get it right. Watch where your turn signal cancellation pin lines up (you'll see it on the back of the boss) if your lucky your turn signals will continue to cancel, if not you'll just go into manuel mode.
CONSTANT CHANGE IS HERE TO STAY.
